Need help in data validation
sujyo
Hello excel gurus...
I want to get Stop Alert(can not enter data) in column F3, G3, H3 when entered data(value) is more then E3 using data validation...
Example:
If E3=100 then in F3 I can enter less then and equal to 100(value of E3),same thing in column G3, H3.
The total of F3, G3, H3 can not be more then E3.
If I enter 100 in F3 then I can not enter anything in column G3 or H3.
If I enter 98 in F3 then I can enter 2 in G3 or H3. or 1 in each.
If E3=0 or empty then I can not enter anything in F3,G3,H3.
No decimals just whole value.
I tryed to make custom formula, less or more then, equal to etc but no luck. I can handle how to set up Alert Messege part. I hope you understand...Thanks in advance
Dear Sujyo,
1. Go to F3 > Data Validation > Whole Number > Less than or equal to > type maximum =E3 > OK
2. Go to F3 > Data Validation > Whole Number > Less than or equal to > type maximum =E3-F3 > OK
2. Go to F3 > Data Validation > Whole Number > Less than or equal to > type maximum =E3-F3-G3 > OK
Done!
Muneer
Hi Sujyo!
Select Cell E3 to H3 > Go to Data Validation > Custom > Enter Formula as
=SUM($F3:$H3)<=$E3
It will solve your problem.. ;)
Deb.
PS: But what about if after VALID input in F3 to H3, someone will change the data in E3.. :)
That's I have added E3 Also in the Validation..
Hi Sujyo,
Adding to the Excel Hero Debraj formula:
Select Cell F3toH3 > Go to Data Validation > Custom > Enter Formula as
=IF($E$3=0,0,SUM($F3:$H3)<=$E3)
If E3 =0 then you are not allowed to enter anything in F3toH3
Thanks,
Suresh Kumar S
PLEASE ACCEPT MY THANKS TO YOU ALL USE THIS FORMULA...
=sum($nazmul_muneer,$Debraj Roy,$Suresh Kumar,$all),"(THANK YOU VERY MUCH"))
Thank you guys...
