I am trying to use conditional formatting along with Text Box(Active X) control on a spreadsheet to find out duplicate values for entered text. The data is downloaded from SAP however when it gets downloaded generally the numbers are either in Text or General format and after putting conditional formatting, it will not show up until I double click on the cell.
After double clicking the cell, the format changes from General to number(i figured out this as aligment of the number changes) and then the conditional formatting works.
Looking forward for some help as the data downloaded from SAP is generally 50,000 to 60,000 records and double clicking every cell will be time consuming as well as not efficient.
Thanks & Regards,
Om Dimri
Thanks & Regards,
Om Dimri
