Need help in arranging the data in xl from Vertical to Horizontal
ans511
Dear experts
I need your help in arranging the data in xl from Vertical to Horizontal.
Attaching the file with Input and output expected.
The main constraints is How man lines a serial number will have is not known
The data file would have large line items
Please help and thanks in advance
Rgds
  • Vertical to Horizontal.xlsx
Hi !
In real worksheet, where starts source area ?
And where output should be ?
Hi Marc
Thanks for the response.
In real work sheet source starts from A1 which is a header and the output can be in a new worksheet or a work book
I hope I answered your question.
Thanks once again
Try this !​
Sub Demo1()
     Sheet2.UsedRange.Clear
With Sheet1.Cells(1).CurrentRegion.Rows
        .Item("1:2").Copy Sheet2.Cells(1)
        L& = 2
    For R& = 3 To .Count
         V = Application.Match(.Cells(R, 1).Value, Sheet2.UsedRange.Columns(1), 0)
        If IsError(V) Then
            L = L + 1
            .Item(R).Copy Sheet2.Cells(L, 1)
            .Item(R).Columns("B:C").Copy Sheet2.Cells(V, 1).End(xlToRight)(1, 2)
With Sheet2.UsedRange.Rows
     Application.Goto .Cells(1), True
    .HorizontalAlignment = xlCenter
    .Range("B1:C1").Value = [B1:C1&"1"]
    .Range("B1:C1").AutoFill .Cells(2).Resize(, .Columns.Count - 1)
    .Item("2:" & .Count).Borders.ColorIndex = xlAutomatic
Thanks Marc
I got below error
I copied and pasted the code in new book .
Added the data in sheet 1 ...
Added another blank sheet 2..
Attaching herewith the file for your reference
Rgds
Andy
  • Transform.xlsm
Did you first try with your original attachment ?!
Works with both attachments on my side …
Hey Marc it worked I added data in Sheet 2 and I got the result in sheet 1.
Thanks a Ton buddy ....
One question I have , How many rows will it work ?
No rows limit but the result limit is the number of columns … (16384)
How many rows in real source data ?
