Need help for multiple selection
d380013
Dear Experts
Pls refer my sheet .... i want to make out multiple selction is it possible to make out through pivot table
https://docs.google.com/file/d/0B57oFxKylXSFMnFEaUVVYkJ1Yjg/edit?usp=sharing
Dhaval Shah
Hi d380013,
What will be the end result if you select it?? I mean how will it be used then?
Faseeh
Hello Faseeh...
for example u select NIFTY .. & cmp of nifty @ 5600 ( UNDER INDEX FUTURE )
i NEED IN THE MONEY CALL FRM ( INDEX OPTIONS ) IN THE MONEY CALL WITH STRIKE PRICE & OI CHANGE ..( < 5600 IS IN THE MONEY CALLS ) & OPPOSITE FOR IN THE MONEY PUT
Dear Faseeh
pls go through the reference sheet
https://docs.google.com/file/d/0B01xhb1Lk7tmQUo1aXhzamxEMkE/edit?usp=sharing
thanks
