Need help Downloading a file from Webpage using VBA
Dinesh121
Hi All,
I have written a module to login into a webpage, do some operations to pull a report using VBA. I need help in downloading the file in IE. When i click the download option a pop window opens and I am not sure how to connect it in VBA.
Thanks in advance.
Thanks,
Dinesh
Dinesh,
Goto Data and select from web option (Pop-up will appear) then enter the website address, Import and select the range.
Thanks,
Suresh Kumar S
@Suresh The website has only one button it does not have range. When I click the button it gives me a pop window where I have click "Download option" to save the file locally.
@shrivallabha This is my corporate website so i am not sure of sharing . IT would be similar to bank websites where we download the statements.
Let me know if I am not clear also Thanks a lot for helping me out
Thanks shrivallabha .. I will check and if I find the answer i will post in the same thread .. it might be useful to others.
