Need data consolidation VBA code help
Sarah Powell
Trying to create a VBA code that will pick up values from multiple worksheets saved in different locations.
So far I have created a “List” tab with file location, and used this code.
However no values are pulling through. Please can someone help – I am a VBA newbie!
Module 1:
Public strFileName As String
Public currentWB As Workbook
Public dataWB As Workbook
Public strCopyRange As String
Sub GetData()
Dim strWhereToCopy As String, strStartCellColName As String
Dim strListSheet As String
strListSheet = "List"
On Error GoTo ErrH
Sheets(strListSheet).Select
Range("B2").Select
'this is the main loop, we will open the files one by one and copy their data into the masterdata sheet
Set currentWB = ActiveWorkbook
Do While ActiveCell.Value <> ""
strFileName = ActiveCell.Offset(0, 1) & ActiveCell.Value
strCopyRange = ActiveCell.Offset(0, 2) & ":" & ActiveCell.Offset(0, 3)
strWhereToCopy = ActiveCell.Offset(0, 4).Value
strStartCellColName = Mid(ActiveCell.Offset(0, 5), 2, 1)
Application.Workbooks.Open strFileName, UpdateLinks:=False, ReadOnly:=True
Set dataWB = ActiveWorkbook
Range(strCopyRange).Select
Selection.Copy
currentWB.Activate
Sheets(strWhereToCopy).Select
lastRow = LastRowInOneColumn(strStartCellColName)
Cells(lastRow + 1, 1).Select
Selection.PasteSpecial xlPasteValues, xlPasteSpecialOperationNone
dataWB.Close False
Loop
Exit Sub
ErrH:
MsgBox "It seems some file was missing. The data copy operation is not complete."
Exit Sub
Public Function LastRowInOneColumn(col)
'Find the last used row in a Column: column A in this example
'http://www.rondebruin.nl/last.htm
Dim lastRow As Long
With ActiveSheet
lastRow = .Cells(.Rows.Count, col).End(xlUp).Row
LastRowInOneColumn = lastRow
End Function
Hi !
Thanks to use code tags or appropriate icon for code !
First remove On Error codeline to try to see where your logic fails …
Function ColumnLastRow&(Vcol, Optional Under As Boolean)
         ColumnLastRow = Cells(Rows.Count, Vcol).End(xlUp).Row - Under
End Function
Just in case you really need a function for last row
