Sub CopyRowsAcross()
Dim i As Integer
Dim ws1 As Worksheet: Set ws1 = ThisWorkbook.Sheets("Sheet1")
Dim ws2 As Worksheet: Set ws2 = ThisWorkbook.Sheets("Sheet2")
For i = 2 To ws1.Range("B65536").End(xlUp).Row
If ws1.Cells(i, 7) Or ws1.Cells(i, 10) < 0 Then ws1.Rows(i).Copy ws2.Rows(ws2.Cells(ws2.Rows.Count, 2).End(xlUp).Row + 1)
Mail_Selection_Range_Outlook_Body
ws2.Rows.Delete
Sub Mail_Selection_Range_Outlook_Body()
Dim rng As Range
Dim OutApp As Object
Dim OutMail As Object
Dim lEndRow
Dim Value As String
Set rng = Nothing
' Only send the visible cells in the selection.
Set rng = Sheets("Sheet2").Range("A2:J2" & lEndRow).SpecialCells(xlCellTypeVisible)
If rng Is Nothing Then
MsgBox "An unknown error has occurred. "
Exit Sub
With Application
.EnableEvents = False
.ScreenUpdating = False
With OutMail
.To = Sheets("Sheet2").Range("D2").Value
.CC = ""
.BCC = ""
.Subject = "Please review the latest Forecast Variable Report"
.HTMLBody = Sheets("Sheet2").Range("B2").Value & "<p>Text above Excel cells" & "<br><br>" & _
RangetoHTML(rng) & "<br><br>" & _
"Text below Excel cells.</p>"
' In place of the following statement, you can use ".Display" to
' display the e-mail message.
.Display
On Error GoTo 0
With Application
.EnableEvents = True
.ScreenUpdating = True
Set OutMail = Nothing
Set OutApp = Nothing
Function RangetoHTML(rng As Range)
Dim fso As Object
Dim ts As Object
Dim TempFile As String
Dim TempWB As Workbook
TempFile = Environ$("temp") & "/" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
'Copy the range and create a new workbook to past the data in
rng.Copy
Set TempWB = Workbooks.Add(1)
With TempWB.Sheets(1)
.Cells(1).PasteSpecial Paste:=8
.Cells(1).PasteSpecial xlPasteValues, , False, False
.Cells(1).PasteSpecial xlPasteFormats, , False, False
.Cells(1).Select
.DrawingObjects.Visible = True
.DrawingObjects.Delete
On Error GoTo 0
'Publish the sheet to a htm file
With TempWB.PublishObjects.Add( _
SourceType:=xlSourceRange, _
Filename:=TempFile, _
Sheet:=TempWB.Sheets(1).Name, _
Source:=TempWB.Sheets(1).UsedRange.Address, _
HtmlType:=xlHtmlStatic)
.Publish (True)
'Read all data from the htm file into RangetoHTML
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
RangetoHTML = ts.ReadAll
ts.Close
RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
"align=left x:publishsource=")
'Close TempWB
TempWB.Close savechanges:=False
'Delete the htm file we used in this function
Kill TempFile
Set ts = Nothing
Set fso = Nothing
Set TempWB = Nothing
End Function
