Multi-select ListBox issue - Code not working
cacos
Hi!
I'm having a hard time with a multi-select listbox I'm using on a particular file.
Here's the link: https://docs.google.com/file/d/0B9nov_b3A5SvcDAxTWhaaUlRb2s/edit?usp=sharing
The listbox is in the sheet "C2".
The code on the multi-select works OK everywhere except on this file. It's a file that Narayank helped me set up and has Workbook_Open code that I think might be creating the conflict.
Thanks a lot!
I am not sure that the code would work everywhere except this one file. Anyway , replace your existing Update_Click procedure with this :
[pre]
Private Sub Update_Click()
Dim lItem As Integer, j As Integer
Dim selected_items() As String
With Sheets("C2").ListBox1
ReDim selected_items(.ListCount - 1)
For lItem = 0 To .ListCount - 1
If .Selected(lItem) Then
selected_items(j) = .List(lItem)
j = j + 1
Worksheets("CRaw").Range("A1:A100").ClearContents
For lItem = LBound(selected_items) To UBound(selected_items)
If selected_items(lItem) <> "" Then
Sheet10.Range("A100").End(xlUp)(2, 1).Value = selected_items(lItem)
[/pre]
It's perfect Narayan, thanks (yet again). Yes it worked fine in other workbooks, I don't understand why. I'll look into your code it's probably smarter.
Thanks a lot.
