Merge cells having same values
Hi VBA Champs,
Please refer to the attached file.
In col(A) I have incident numbers, now for those incident numbers which are same I want to merge cells in col(A) and also merge cells in col(B) to col(F).
Like I have done manually for INC000012911090 and INC000012974811.
I want a dynamic code so that there may be 56 row data now but later it may be less or greater.
Thanks in advanced.
  • workinfo.xlsx
Hi Ali,
Is it necessary to merge...you can even use pivot table for this...see the attached..
  • MergePT.xlsm
Hi Ali,
Yes it is necessary to merge because my customer is not an excel champ. They only use excel to keep data aligned.
Hence they require a report in the merge cell format.
FYI: I have created a macro to fetch data on the basis of Incident Number from 3 different files to create the report file I had shared. Now the final step remaining is to merge cells for duplicate incidents.
Hello everyone,
I have come up with a code but it is not perfect. Please help
  • workinfo.xlsm
Hi Ali ,
See if this works.
At present , the merging is being done only in column A ; in reality this should be done in all the columns which you want merged ; you should not run this macro on each column independently.
  • workinfo.xlsm
Hi Narayan Sir,
I have done with a code which does it all.
I am not sure about the quality of my code, any suggestions from your side is welcome.
Sub MergeIncidentNumbers()
Worksheets("workinfo_data").Activate 'TO ACTIVATE WORKSHEET CONTAINING DATA
'TO BYPASS MERGE CELL WARNING
n = Cells(Rows.Count, "a").End(xlUp).Row 'TO COUNT NUMBER OF ROWS IN DATA
Range("A2:E" & n).Sort key1:=Range("A2:A" & n), _
   order1:=xlAscending, Header:=xlYes
Count = 2 'COUNTER TO HOP FOR NEXT INCIDENT NUMBER
For i = 2 To n
If Range("a" & Count) = Range("a" & i) Then
'MERGE CELLS HAVING SAME INCIDENT NUMBER
Range("a" & Count & ":" & "a" & i).Select 'COL CONTAINING INCIDENT NUMBERS
Selection.Merge
Range("b" & Count & ":" & "b" & i).Select '/
Selection.Merge
Range("c" & Count & ":" & "c" & i).Select '/
Selection.Merge
Range("d" & Count & ":" & "d" & i).Select 'CELLS TO BE MERGE INDEPENDTLY FOR HAVING SAME INCIDENT NUMBERS
Selection.Merge
Range("e" & Count & ":" & "e" & i).Select '/
Selection.Merge
Range("f" & Count & ":" & "f" & i).Select '/
Selection.Merge
Count = i 'TO MOVE TO NEXT INCIDENT NUMBER
'TO SET ALIGNMENT OF CONTENTS WITHIN MERGRE CELLS
Columns("A:F").VerticalAlignment = xlCenter
Hi Ali ,
Please see if the file I uploaded earlier works ; if it does , you can easily extend the merge to the associated columns.
This should do
Sub test()
    Dim r As Range, i As Long
    Columns(1).Insert
    With Range("b2", Range("b" & Rows.Count).End(xlUp)).Offset(, -1)
        .Formula = "=if(b1<>b2,if(a1=1,""a"",1),"""")"
        .Value = .Value
        .SpecialCells(2, 1).EntireRow.Insert
        .SpecialCells(2, 2).EntireRow.Insert
        On Error GoTo 0
    For Each r In Columns(2).SpecialCells(2).Areas
        If (r.Rows.Count > 1) * (Not r.MergeCells) Then
            For i = 1 To 6
                r.Columns(i).Merge
    Columns(1).Delete
    Range("g1", Range("g" & Rows.Count).End(xlUp)).SpecialCells(4).EntireRow.Delete
