Max Function with range refering to other cell... Unsuccessful
bigjohn
Working with Max Function as described above.
This is the formula that got stuck with:
=MAX("G"&(D1-C1):"G"&(D1))
D1 = LARGE(E1:E100,1)
C1 = Number of row (Data, Not a formula)
Tried the array key press but result, #value.
Try this , entered as a normal formula , NOT an array formula :
=MAX(INDIRECT("G"&(D1-C1)):INDIRECT("G"&D1))
I entered some values in column E , so that D1 returned the value 99 as the maximum value in the range E1:E100.
Then I entered the value 73 in cell C1.
The above formula then returned the maximum value in the range G26:G99 , since D1-C1 = 99-73 = 26.
