andreas.wpv
I have two lists of urls i want to compare - but match does not find the matches.
Formula is =match(B2,$A$2:$A$4,0) = I only get n/a, although they are the same.
I set the format of url fields to text - still not working. vlookup gives me numbers back, but totally wrong numbers
Formula is =VLOOKUP(D2,$A$2:$B$4,2) (i moved the url to compare into D, and added a row with =row() to get the row number in B = column 2.
If I search (ctrl F) excel wont find the match.
BUT if I check =IF(B2=A4,"true","false") i get a TRUE!
So excel sees them as the same, but cannot search, match or lookup?
http://content.name.com/d/corporate~case-studies~en/Documents~2010-grupo-sese-10009110.pdf.aspx?c=ec&cs=ecbiz1&l=en&s=biz http://content.name.com/d/corporate~case-studies~en/Documents~2011-kafkas-10008274.pdf.aspx?c=ec&cs=ecbiz1&l=en&s=biz #N/A
http://content.name.com/d/corporate~case-studies~en/Documents~2011-bupa-cromwell-10008910.pdf.aspx?c=uk&cs=RC1050265&l=en&s=pad http://content.name.com/d/corporate~case-studies~en/Documents~2010-grupo-sese-10009110.pdf.aspx?c=ec&cs=ecbiz1&l=en&s=biz #N/A
http://content.name.com/d/corporate~case-studies~en/Documents~2011-kafkas-10008274.pdf.aspx?c=ec&cs=ecbiz1&l=en&s=biz http://content.name.com/d/corporate~case-studies~en/Documents~2011-bupa-cromwell-10008910.pdf.aspx?c=uk&cs=RC1050265&l=en&s=pad #N/A
