MATCH FUNCTION using 1 as match type....please help
PP3321
I have the following formula:
=MATCH(1,{0,0,0,0},1)
This returns 4.
This is very mysterious to me.
Syntax: MATCH(lookup_value,lookup_array,match_type)
If match_type is 1, MATCH finds the largest value that is less than or equal to lookup_value. The argument lookup_array must be placed in ascending order: ...-2, -1, 0, 1, 2, ..., A-Z, FALSE, TRUE.
When I did the simple formula.
=INDEX(B2:B4,MATCH(A6,A2:A4,1))
So if it finds equal value, then first occurance.
But not equal value, then the last occurance....
I think I got confused there...
@PP3321=INDEX(B2:B4,MATCH(A6,A2:A4,1))
... not good to use match_type 1,
You should use 0 for match_type.
  • If match_type is 1, The argument lookup_array must be placed in ascending order.
  • If match_type is 0, The argument lookup_array can be in any order.
  • If match_type is -1, The argument lookup_array must be placed in descending order.
