Match and index with additional column
OH OK< Now AliGW has posted - i see what you wanted
for Older versions of excel
=INDEX(D$4:D$15,MATCH($H$3&$I$3,$B$4:$B$15&$C$4:$C$15,0))
sorry not following the logic - why is your ex ...
what version of excel are you using
can you give some expected results and why - based on the example table
I'll assume you have 365.
In H3: C
In I3: 07/12/2025
In J3 followed by ENTER:
=DROP(GROUPBY(HSTACK(B4:B15,C4:C15),HSTACK(D4:D15,E4:E15,F4:F15),SUM,,0,,(B4:B15=H3)*(C4:C15=I3)),,2)
AliGW on MS365 Beta Channel (Windows 11) 64 bit
[Table="width:, class:head"][tr=bgcolor:#888888][th] [/th][th]
H
[/th][th]
I
[/th][th]
J
[/th][th]
K
[/th][th]
L
[/th][/tr]
[tr=bgcolor:#FFFFFF][td=bgcolor:#888888]
2
[/td][td]
Domain
[/td][td]
Date
[/td][td]
Pass
[/td][td]
Fail
[/td][td]
Blocked
[/td][/tr]
3
[/td][td]
C
[/td][td]
12/07/2025​
[/td][td]
2​
[/td][td]
4​
[/td][td]
2​
[/td][/tr]
[/table]
[Table="width:, class:grid"][tr][td]Sheet: Sheet1[/td][/tr][/table]
The results that you have shown in the excel are correct, I want in the same fashion...but you have selected that particular column to bring the result.
Can we have something else such that the formula becomes dynamic and no matter where the column is placed it should pick it like we get in match and index
In H3: C
In I3: 07/12/2025
H
I
J
K
L
2
Domain
Date
Pass
Fail
Blocked
3
C
12/07/2025​
2​
4​
2​
Sheet: Sheet1
this worked..but is a bit complex for my brain... :)
