Tim Hanson
I am trying to use a Dictionary object for first time and am confused!
I am trying to compare columns on 2 different sheets then post back to a 3rd sheet
I get the proper number of matched rows but no matches( they are all "0")
I uploaded a workbook
In module2 I have a matching Macro "RemoveRowsByMatch" I used the generate the "Want" tab, I am trying to duplicate "RemoveRowsByMatch" using a Dictionary object because I think it is faster and I am trying to get an idea of how to use a Dictionary objects
Thanks for any help on this
Thank you
Thank you
Sub FindDistinct()
Dim dict As Object
Dim arr As Variant
Dim wsS As Worksheet, wsFind As Worksheet, wsPB As Worksheet
Dim Counter As Long
With Application
.ScreenUpdating = False
.Calculation = xlCalculationManual
Set dict = CreateObject("Scripting.Dictionary")
Set wsS = ThisWorkbook.Sheets("XXX")
Set wsFind = ThisWorkbook.Sheets("YYY")
Set wsPB = ThisWorkbook.Sheets("ZZZ")
arrS = wsS.Range("A2", wsS.Cells(wsS.Rows.Count, "A")).Value
arrFind = wsFind.Range("A2", wsFind.Cells(wsFind.Rows.Count, "A")).Value
With wsS
dict.CompareMode = vbTextCompare
For Counter = 1 To UBound(arrS, 1)
If Not dict.Exists(arrS(Counter, 1)) Then dict.Add arrS(Counter, 1), arrFind(Counter, 1)
On Error GoTo 0
With wsPB
.Range("A1") = "Dictionary"
arrS = dict.Items
.Range("A2").Resize(dict.Count, 1).Value = Application.Transpose(arr)
Set dic = Nothing
' Resize columns as needed
.Columns.AutoFit
With Application
.ScreenUpdating = True
.Calculation = xlCalculationAutomatic
MsgBox "Done"
