Macro to split data to their respective columns
RAM72
Need a macro to split data in their respective columns as per attached file
The data goes up to 20000 rows
One column is always 8 digits the second column is alpha numeric , the third always 2 alphabet and the fouth column is alphanumerical .The word total is ignored
  • BREAKDOWN.xlsx
Code to paste to worksheet module :​
Sub Demo1()
    VA = Cells(1).CurrentRegion.Value
    ReDim VR(2 To UBound(VA), 1 To 4)
For R& = 2 To UBound(VA)
                                         SP = Split(VA(R, 1))
                                   VR(R, 1) = SP(0)
                                   VR(R, 2) = SP(1)
                                   VR(R, 3) = SP(UBound(SP) - 2)
                                   VR(R, 4) = SP(UBound(SP) - 1)
    For C% = 2 To UBound(SP) - 3:  VR(R, 2) = VR(R, 2) & " " & SP(C):  Next
    [A2:D2].Resize(UBound(VR) - 1).Value = VR
    Cells(1).CurrentRegion.Columns.AutoFit
Could do this with just formulas, but here you go.
Sub WriteFormulas()
Dim lastRow As Long
Dim ws As Worksheet
'Which sheet to work on?
Set ws = ActiveSheet
With ws
    'Find the last row of data
    lastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
    'Build the formulas
    .Range("B2:B" & lastRow).Formula = "=1*LEFT(A2,8)"
    .Range("C2:C" & lastRow).Formula = "=MID(LEFT(A2,FIND("" ""&D9&"" "",A2)-1),10,999)"
    .Range("D2:D" & lastRow).Formula = "=LEFT(RIGHT(A2,14),2)"
    .Range("E2:E" & lastRow).Formula = "=LEFT(RIGHT(A2,11),5)*1"
    'If you want static values, use this bit
    With .Range("B2:E" & lastRow)
        .Copy
        .PasteSpecial xlPasteValues
Sub WriteFormulas()
Dim lastRow As Long
Dim ws As Worksheet
With ws
    'Build the formulas
        .Copy
Hi Luke
Tested code, working
but giving in column C header description # value!
Some adjustments needed in the formula column C
Coding No Description Qty Po
39173900 #VALUE! CN 14178
39173900 #VALUE! CN 14216
39174000 #VALUE! CN 14216
39189000 #VALUE! FR 13691
Sub WriteFormulas()
Dim lastRow As Long
Dim ws As Worksheet
With ws
    'Build the formulas
        .Copy
Sub Demo1()
                                   VR(R, 1) = SP(0)
                                   VR(R, 2) = SP(1)
Thanks Marc working perfectly
I goofed. :(
code line correction:
.Range("C2:C" & lastRow).Formula = "=MID(LEFT(A2,FIND("" ""&D2&"" "",A2)-1),10,999)"
Accidentally had D9 rather than D2. Doh!
