Been looking for a Macro to search in Column U and look in column C to find what numbers do not match then cut the Cells found in that row under Column U through Column Z and then paste the data in the last blank row under Column U. Sometimes there it will always match and then there is one or more that will not match. Both columns will always be a number. What is happening I am comparing data from last weeks pull from a database then compare the data is a current pull to see what has changed, that part is work fine, the problem is when a new entry is added the current data will have one or more extra entries and the side by side comparison is out of line so my Lookup and IF statements all flag. I need to take those in Column U that is a new Unique ID number that was added cut those cells and then find last cell under Column U and paste the data there and loop till all new numbers are at the bottom. The spreadsheet is sorting first by a column that is one location xyz then by the unique ID in ascending order. So under xyz the other specific area is ABC and then those unique numbers or sorted ascending. So when a new unique number is added to xyz then the comparison of side by side is out of sequence to match up. Sorry for being so wordy.Thank you for your help on this.
