Macro to generate running total
Hello again,
I have the attached code which takes Data inputted by Users and does two things:
1) Makes a list of each entry. This part is working.
2) Supposed to take Value based on RC_Number and Add it to a running Total (in this example 'FrankSubtotal', this is where it falls apart. It continuously re saves over existing value.
For example if the User Selects RC_Number 3201 on the first pass and enters a value of $10. Cells AA2 would be filled:3201, Cells AB2 would be filled: Frank and Cells AC2 would be $10. The Cells D9 would have the Value $10.
Now on the next pass if the User selects RC_Number 3201 AGAIN and enters a value of $25. Cells AA3 would be filled:3201, Cells AB3 would be filled: Frank and Cells AC3 would be $25 (this part is working). The Cells D9 should have the Value $35. But I'm getting Cells D9 as $25.
Does anyone see my error??
Kinda Yes, kinda no. Here's what worked:
        If Me.RC_Numbers.Text = 3201 Then
            ADMGOVSubtotal = Range("D9").Value + Me.Expense.Value
            Range("D9").Value = ADMGOVSubtotal
[CODE]
And Thanks for your help! All the Excel ninjas here are great
