Macro required for changing numbers to specific text
amolryeolekar
I have this date I have 3 Euiprments, I want to make a macro for replace numbers to eduipment name ,where cell contains value 1 till before next cell value =1 will be one equipment no i.e EQ1 then for next cell value=1 then EQ2 till next cell value is 1 and so on
All numbers (number of rows of any equipment will be vary time to time )
How to automate by macro
Ex-
Srno
1
2
3
1
2
3
4
5
6
1
2
3
srno
EQ1
EQ1
EQ1
EQ2
EQ2
EQ2
EQ2
EQ2
EQ2
EQ3
EQ3
EQ3
Hi Amol ,
You can do the same using formulae ; if your data is in column A , starting from A2 , and you want the equipment numbers to appear in column B , enter the following formula in B2 and copy downwards :
="EQ"&COUNTIF($A$2:A2,1)
I am assuming that the equipment number should change every time a 1 is encountered in column A.
@NARAYANK991
Hi!
It does the job correctly, but I'd like more one of these two slight variations:
="EQ"&COUNTIF(A$2:A2,1)
="EQ"&COUNTIF($A$2:$A2,1)
In that order of choice.
Regards!
