Macro paste value not formula help
maku
I've pieced together a macro that goes through all my worksheets and pastes data from worksheets that contain data tables to a Master Data worksheet.
The problem is, I have formulas in some of the data table on the individual worksheets, but don't want the formula copied from that worksheet to the Master Data table, I just want the actual value that is shown on that worksheet to be copied.
Here is my code (that copies data & formulas), but I don't know if I need to do a Paste Special somewhere in it to achieve this.
Thank you,
-Maku
ps- the end part of the code referencing the parameters sheet is copying the header to the master data table.
[pre]
Dim wsMain As Worksheet
Dim ws As Worksheet
Dim FValue As String
Dim i As Long
Dim lrow As Long
Sub ConsolidateMasterData()
FValue = "Year"
Set wsMain = Worksheets("Master Data")
wsMain.Cells.Clear
lrow = Worksheets("Master Data").Range("A" & Rows.Count).End(xlUp).Row
For i = 1 To Worksheets.Count
With Worksheets(i)
If .Name <> "Master Data" Then
lrow = .Range("G" & .Rows.Count).End(xlUp).Row
If .Range("G2").Value <> "" Then
If .Range("G1") = FValue Then
.Range("G2:AB" & lrow).Copy Worksheets("Master Data").Range("A" & Rows.Count).End(xlUp).Offset(1, 0)
Sheets("parameters").Range("AA1:AV1").Copy _
Destination:=Sheets("Master Data").Range("A1")
[/pre]
Hi, Maku!
Replace the statement:
by:
.Range("G2:AB" & lrow).Select
Selection.Copy
Worksheets("Master Data").Range("A" & Rows.Count).End(xlUp).Offset(1, 0).Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
Regards!
SirJB7, why do all that extra selecting? =)
[pre]
Worksheets("Master Data").Range("A" & Rows.Count).End(xlUp).Offset(1, 0).PasteSpecial _
[/pre]
SirJB7,
I thought it was PasteSpecial that was needed, but didn't know how to separate the syntax out. Thank you!
Your code didn't quite work, it created a Run-Timer error '1004' Select Method of Range Class Failed.
I altered your code adjustment a little, and it works as desired.
Worksheets("Master Data").Range("A" & Rows.Count).End(xlUp).Offset(1, 0).PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
THanks again for the assistance.
-Maku
ooohh...I see Luke beat me too it, I guess that's because I worked on trial and error and Luke is the master :)
Seriously though, thank you, I was able to get it with your help.
Glad you were able to figure it out on your own. =)
If nothing else, I find it usually helps me learn/remember something better that way.
