Macro needs help
As far as the simpler requirement is concerned , the code is as shown below :
Private Sub Workbook_BeforeClose(Cancel As Boolean)
        Application.StatusBar = "This automation tool is prepared by 'Surendra (Sunny Singh)' on 28/Sep/2013. Please contact at 'xxxxxxxxxxx@xxxxxxx.xxx' for any further assistance."
        ThisWorkbook.Save
        MsgBox "This Excel-VBA automation project is made for 'Kyrre Sandvik'." & vbNewLine & vbNewLine & _
                "by Surendra (Sunny Singh)" & vbNewLine & _
                "Microsoft Certified Excel" & Chr(174) & " 2010 (MCP)", vbInformation, "Thank you!"
    On Error GoTo 0
The offending statements are the following :
Just remove these two statements , and you should no longer get the popup when closing the file.
Hi Kyrre,
It was the one picture at the top of the TIMELISTE worksheet that was causing the extra 900kb in file size. I've taken your file and "put it on a diet" by removing all the old named ranges that contained errors, implemented a XL table, and got rid of unused/unwanted code. The new macro "DoItAll" will copy data from Ask1 to CSV, do the Text-to-Columns, and then transfer to TIMELISTE worksheet. You also still have the individual buttons, if that is needed.
Apologies if I butchered something up with the language. :(
The picture:oops::rolleyes: How stupid of me.,., Yes it is often the small things that crashes things up.
The macro was exactly what i was looking for- almost:) And I can see that it is my mistake.
The macro must run from no.4, not from no 1 as I have by mistake asked for.
I get csv from another sheet- so I have to copy and paste the csv into csv-tab for further prosessing( change name in dropdown)
Is it poosible to cange that? I am very glad for this help:)
Easy enough. If you look at the macro, there's 3 sections. The first section is the transfer from Ark1 to CSV, but it sounds like we don't need that.
Current code:
Sub DoItAll()
Dim lastRow As Long
'TRANSFER INFO FROM ARK1 TO CSV
'Clear out previous data
Call NullStill_New
With Worksheets("Ark1")
    'Find the last row of our data on Ark1 sheet
    lastRow = .Cells(.Rows.Count, "A").End(xlUp).Row
    If lastRow < 2 Then
        MsgBox "Please paste data into row 2 below.", vbOKOnly, "No Data"
        GoTo escapeClause
    'Copy the data to CSV sheet
    .Range("A2:A" & lastRow).Copy Worksheets("CSV").Range("B4")
'SPLIT THE DATA INTO CORRECT CELLS
'Use our existing macro to split the data
Call Csv_til_excel_New
'TRANSFER TO MAIN TABLE
With Worksheets("CSV")
    lastRow = .Cells(.Rows.Count, "B").End(xlUp).Row
    .Range("A4:F" & lastRow).Copy
With WshTimeListFromCSV
    .Cells(.Rows.Count, "A").End(xlUp).Offset(1, 0).PasteSpecial (xlPasteValues)
escapeClause:
And based on what you just said, remove the first bit
Sub DoItAll()
Dim lastRow As Long
'This section is what the "Gjør om" button calls.
escapeClause:
I will look into this, and try to figure it out (how the code works, not just use it)
I am very greatful, you are awesome!:awesome:
However, I cant find the macro with this text"Application.StatusBar = "This automation tool is prepared by 'Surendra (Sunny Singh)' on 28/Sep/2013. Please contact at 'xxxxx",....,
I open Macro, step in it and look around. cant find it. Do I need glasses?
I believe I removed it from the workbook I posted it. If it's still there, it would be in the ThisWorkbook module (look in the VBE explorer window). You can also use Ctrl+f (find dialogue) and search the entire project for "Surendra". But again, I'm 99% sure I already removed it.
