macro does not work after renaming workbook
codedreamer
I have two workbooks, one name BakeSale and one name Receipt. The macro is supose to transfer information from Bake Sale to receipt, but after the workbook is rename it does not work anymore. This is what I have:
'Workbooks("BakeSale.xlsm").Sheets(i).Range("A1").Value =Workbooks("Receipt.xlsm").Sheets(i).Range("A5").Value'
I tried substituting BakeSale for ThisWorkbook and it pass that line, but it does not pass the next even though Receipt has not been rename.
Thank you for your help,
Codedreamer
Hi Codedreamer!
First, as a tip, the mark for posting code is backtick (under the Esc key), not a single apostrophe. It's a little confusing I know.
Just to check, is this what you tried before?
ThisWorkbook.Sheets(i).Range("A1").Value =Workbooks("Receipt.xlsm").Sheets(i).Range("A5").Value
Code is also assuming that the Receipt workbook is already open. If that single line is working okay, perhaps there is something else in the block of code that is doing something funny. I'm presuming that this is in some sort of For...next loop?
Do you have any Chart sheets in either workbook? That would cause an error. If you could post more of your code, that would be helpful as well.
