Keep spacing between Pivots
Gman
Hello all I am beginning to make a dashboard but have run into an issue. I will have multiple pivot tables, and they will change in size as the month goes on. I want to keep the spacing between them the same at all times. I also need it to update the spacing automatically so when data for a new day gets added it shows that day and keeps the 3 spaces (rows 15,16,17) before next pivot starts.
Thanks in advance for the help.
Gman
  • example.xlsx
Put this in to a vba sub :-
Const blanks =3
Dim lastValue AsString, i AsLong, r AsLong
Do
r = r +1
If r >1 And lastValue <> Cells(r,1).Value Then
If Cells(r,1).Value = "" ThenExitDo
For i =1 To blanks
Rows(r).Insert Shift:=xlDown
r = r + blanks
EndIf
lastValue = Cells(r,1).Value
Loop
Const blanks =3
Do
r = r +1
For i =1 To blanks
r = r + blanks
EndIf
Loop
I have tried the code you provided, unfortunately when I tried to run it gave me a "Run-time error '1004': We can't make this change for the selected cells because it will affect a PivotTable. Use the field list to change the report. If you are trying to insert or delete cells, move the PivotTable and try again."
