It is Necessary to Shifting excel Up,down,Left,Right,after remove Row Or Column?
Dear Sirs,
It is necessary to shifting range after delete rows or columns in excel through VBA?
because if you delete rows or columns in excel , excel automatically shift ranges to left or up . Excel's this action is reliable for Auto-reset used range?
Some times seen that used range don't reset without explicitly forced as shifting ranges
after delete or remove rows or columns so what should be next action after delete rows or columns?
another point for cells, what is the default behaviour of shifting after delete or remove cell from the range? if, cells need to delete from range, what is necessary as next action?
Please help as spread universal guide on shifting.
Chirag Raval
If you delete a row or column, there is only one possible way for other cells to shift, so no real need to specify it. In any other case you should specify - relying on defaults is just bad practice generally.
Hi !
Yes it can occurs, disappears after saving and closing workbook …
A tip on VBA side only if the worsheet is active just add this codeline :
ActiveSheet.UsedRange
Or just using usual workarounds like CurrentRegion
Another tip to avoid deleting rows within a loop
is to sort and Clear at once, a faster way …
