INDEX SMALL with >
Busymanjohn
Hi all, I am having some trouble with getting the required results from a multiple VLOOKUP ( INDEX, SMALL ) when I input a > sign rather than an = sign ..... i.e. my formula is INDEX(page!$B$1:$U$2671,SMALL(IF(page!$B$1:$B$2671=3,ROW(page!$B$1:$B$2671)),ROW(page!1:1))*1,2)
page is the sheet name that contains my data, full range of the data is in cols B to U, with col B containing the start point ( number of days in this case ) ... formula works fine with an = sign after the IF statement (IF(page!$B$1:$B$2671=3, but when I change the = sign to a > sign the result is error or returns the value in the cell above .... is there something significant about using a > sign in this formula?
John
Two things to try ,
1. Hit Shift+Ctrl+ Enter in formula bar. then you see formula will {...} .
2. try to put =>.
upload sample sheet for faster response.
-Ashwin
Sample file attached ,,,, Ashu, I know about the array ( should have mentioned that already ) ,,,, I have highlighted in the attached the data that should be returned, but one line is missing from the result.
Hi John,
I think you just need a small amendment, highlighted in Red:
=IFERROR(INDEX($B$2:$E$11,SMALL(IF($B$2:$B$11>=4,ROW($B$2:$B$11)-1),ROW(1:1)),COLUMN(B1)),"")
CSE...
I have also replaced 2 with COLUMN(B1), column number will be updated when you drag to right. You can also use the MATCH function here.
