Index(Max(if?
Please refer to the attached file.
What I require is in A1 the value from F3:F10 column that corresponds with the MAX value in A3:A10. A1 should come out as 2 because 49 is the max in that column.
This is to continue B1 through E1
When there are 2 or more identical Max values in the same column such as in B and C) the higher corresponding value in G3:G10 column should act as the tie breaker.
B1 should be 6 because the 55 in G, C1 should be 5 because of the 65 in G
I have been trying the following
=INDEX($A$3:$G$10,IF(A2=1,MAX($A$3:$A$10),MAX($G$3:$G$10)),6)
But am getting back a #REF! error
@Jamie Wagler
#REF comes because Your row value is over 8 (49 or 65).
You could test next to cell[A1] ... ";" or ","
=INDEX($A3:$G10;MATCH(MAX(A3:A10);A3:A10;0);6)
or
=INDEX($A3:$G10;MATCH(MAX(A3:A10),A3:A10,0),6)
Following seems to work. I think there could be elegant alternative. This is array formula so you have to commit by Control+Shift+Enter. In cell A1:
=INDEX($F$3:$F$10,MATCH(MAX(IF(A3:A10=MAX(A3:A10),1,0)*$G$3:$G$10),IF(A3:A10=MAX(A3:A10),1,0)*$G$3:$G$10,0))
One more--
MAX(IF((A$3:A$10=MAX(A$3:A$10))*$G$3:$G$10=MAX(IF(A$3:A$10=MAX(A$3:A$10),$G$3:$G$10)),$F$3:$F$10))
TO be array entered
@Asheesh Not sure if it is complete duplicate but the file provided is the same but requirements are stated bit differently (MAX here and commonly appearing number).
@bines53 You have overlooked tie part.
Hi to all!
This could work:
=LOOKUP(2,1/(A3:A10+$G3:$G10/9^9=MAX(A3:A10+$G3:$G10/9^9)),$F3:$F10)
Or:
=LOOKUP(,0/FREQUENCY(0,1/(A3:A10+$G3:$G10/9^9)),$F3:$F10)
Blessings!
Hello friends,
Here's my solution,
=MATCH(MAX(MMULT((A3:A10=MAX(A3:A10))*$G$3:$G$10,1)),MMULT((A3:A10=MAX(A3:A10))*$G$3:$G$10,1),0)
David
Another, shorter,
=MATCH(MAX(MMULT((A3:A10)*($G$3:$G$10),1)),MMULT((A3:A10)*($G$3:$G$10),1),0)
=AGGREGATE(14,6,ROW(A3:A10)-2/((A3:A10)*($G$3:$G$10)=MAX((A3:A10)*($G$3:$G$10))),1)
=MAX(MMULT(N((A3:A10)*($G$3:$G$10)=MAX((A3:A10)*($G$3:$G$10)))*ROW(A3:A10)-2,1))
David
