INDEX/MATCH :VBA codes
Binaxxx
I am looking for to change the below as VBA codes and make it dynamic :
I do not know where to start
=IFERROR(INDEX(PO_Detail!C:C,MATCH(1,(PO_Detail!A:A=VD_Backlog!A2)*(PO_Detail!B:B=VD_Backlog!B2),0))," ")
Please find attached a workbook with two tabs :
- VD_Backlog
_PO_Detail
The formula is within column C.
I'd like this formula to be generate through VBA and the cells will have only the "Value" found and not the formula
Many thanks for your help
Using Scritping.Dictionary.
Sub Demo()
Dim poDic As Object
Dim poArr
Dim cel As Range
Set poDic = CreateObject("Scripting.Dictionary")
With Sheets("PO_Detail")
    poArr = .Range("A2:E" & .Cells(Rows.Count, 1).End(xlUp).Row).Value
For i = 1 To UBound(poArr)
    poDic(poArr(i, 1)) = poArr(i, 3)
With Sheets("VD_Backlog")
    For Each cel In .Range("A2:A" & .Cells(Rows.Count, 1).End(xlUp).Row).Cells
        cel.Offset(, 2) = poDic(cel.Value)
Sub Demo()
Dim poDic As Object
Dim poArr
Dim cel As Range
Hi CHIHIRO,
This is great, however the lookup does not mention the second criteria to generate the lookup. As a matter of fact the codes return a wrong value.
Ah, Column B. I missed that. See modified code (just the concatenation of Column B to A).
Sub Demo()
Dim poDic As Object
Dim poArr
Dim cel As Range
    poDic(poArr(i, 1) & "," & poArr(i, 2)) = poArr(i, 3)
        cel.Offset(, 2) = poDic(cel.Value & "," & cel.Offset(, 1).Value)
