Hi all thanks for reading, Basically I've got the following
Col A-----------------Col B---------------------Col C--------------------Col D
Building ID-----------Count---------------------Rental Rate---------------Rank
in col A i have a list of building id's, including duplicates as each building may have one or more rental rates and each rental rate generates a record. I have used count in col B as i thought this might help. Col C contains the rental rates for each corresponding building ID and in Col D i want to rank the rental rates for each building separately.
The closest i've come (and i've tried several different trains of thought) is
=IF(B2=1,1,IF(B2=2,RANK(C2,$C2:$C3,0),IF(B2=3,RANK(C2,($C2:$C4),0),0)))
but as you can immediately see this fails when there are 2 or more occurances of a building id as the reference needs to apply to 2 or 3 rows, depending on how many occurances of the buidling id.
For example if i have...
Col A-------------------Col B---------------------Col C--------------------Col D
Building ID-------------Count---------------------Rental Rate---------------Rank
07644525------------------1---------------------------10----------------------1
07644675------------------1----------------------------7----------------------1
07755000------------------1---------------------------11.5--------------------1
08149000------------------1----------------------------5----------------------1
08457000------------------1---------------------------10----------------------1
09392000------------------1---------------------------10----------------------1
00802000------------------2---------------------------10----------------------1
00802000------------------2---------------------------9.5---------------------1
00842000------------------2---------------------------7-----------------------1
00842000------------------2---------------------------5-----------------------2
00843000------------------2---------------------------7-----------------------1
00843000------------------2---------------------------5-----------------------2
00877000------------------2---------------------------10----------------------1
00877000------------------2---------------------------9.5---------------------2
00884000------------------2---------------------------10----------------------1
00884000------------------2---------------------------9.5---------------------1
00889000------------------2---------------------------8.5---------------------1
00889000------------------2---------------------------8-----------------------2
05469000------------------3---------------------------6-----------------------1
05469000------------------3---------------------------5-----------------------2
05469000------------------3---------------------------1.4---------------------3
11162750------------------3---------------------------5.5---------------------1
11162750------------------3---------------------------3-----------------------2
11162750------------------3---------------------------2.75--------------------3
19000000------------------3---------------------------10----------------------1
19000000------------------3---------------------------9.5---------------------1
19000000------------------3---------------------------5-----------------------1
You can see that the rank does not work with multiple entries because the ref array in the rank ($C2:$C3,0),IF(B2=3,RANK(C2,($C2:$C4) would need to look like $C$2:C$3 for 2 occurances and $C$2:$C$4 for 3 occurances, however formatted like this obviously would apply only this specific ($C$2:$C$4) series of ref cells down the whole list...
I need it to be able to find and rank however many rental rates are associated with each bldg id... i don't know if Index and Match would do this? I think if there were such thing as a RANKPRODUCT like a sumproduct formula, that might work... any ideas?
Thanks,
Joe
Thanks,
Joe
