Index Match problem
I have a list of values in column FM on Sheet1. I need to match these values from column FM Sheet1 with those in column A Sheet2 and populate column F Sheet1 with the values from column D Sheet2.
SHEET1
....F...............FM
Order.........Values
..................91001
..................90701
..................90077
..................90049
SHEET2
A...................D
Values.........Order
90077............1
90701............2
90049............3
I am not sure I have understood you correctly , but the way you have duplicates in column FM , you will have duplicates in column F also ; is that OK ? if so , try this :
=IFERROR(INDEX(Sheet2!$D$2:$D$4,MATCH(Sheet1!FM2,Sheet2!$A$2:$A$4,0)),"")
I have assumed your data starts from row 2 in both sheets.
Hi, vicmoment!
HLOOKUP & VLOOKUP searches are equivalent to INDEX + MATCH, so satisfying your curiosity, yes, in this case it'd work equally.
Regards!
