Index Match not working
Hi, Could you please refer attached worksheet and help where i went wrong with the index match formula ? Thanks
  • Simple Index Match.xlsx
I think it should be:
=INDEX($D$8:$D$20,MATCH($C2&$D2,$B$8:$B$20&$C$8:$C$20,0),)
With Ctrl+Shift+Enter
INDEX syntex is INDEX(array, row_num, [column_num]) while your array consists of a single column. Your data is not arranged in the right form to utilize this formula with multiple conditions.
Attached is my suggestion for a solution.
Oren
