cparks
Having an issue with using some of my "index/match" formulas. When I use my named ranges or when i select a larger range (column) than what that particular column visibly shows, I either get "0" or nothing at all...aside from using either IFERROR, ISBLANK, etc.
I know (or at least Im fairly certain) that when using lookup type formulas each array/criteria range needs to be the same amount of cells.
What gets me is when I select JUST the populated cells (i.e. visible), then the index/match formula works.
What am I missing?
Attached file enclosed.
RED TABS are the target sheets
RED BORDERED COLUMNS are the target columns
GREY SHADED AREAS is how far down formulas go/do not not exceed
Trouble Column with INDEX/MATCH formula: EVALS, Column B
What am I missing?
