Index Match formulas > case sensitive IDs
rfreeman
I have been using vlookups for most of my day to reporting tasks, but am coming across some errors, and a colleague said using Index/Matching formulas is much better.
A problem I have is with the below formula because the IDs are slightly case sensitive i.e. "001a000001KYl9a" refers to a different account than "001a000001KYl9A"
Formula belwo causes invalid data errors
=VLOOKUP($B:$B,'[Sales Report]Accounts'!$B:$B,2,FALSE)
How do I transfer this into a Index/Matching formula
The errors in your formula are not because VLOOKUP is inferior to INDEX/MATCH ; the issue is just the syntax.
The third parameter in the VLOOKUP function is supposed to refer to a column number within the range specified as the second parameter , so that when a match is found in the first column of the range , the corresponding value from the specified column is returned.
To give an example , suppose the second parameter is G7:Z23 ; this is a range which is 20 columns wide ; to return a valid result from a VLOOKUP formula using this range , the third parameter can vary from 1 through 20 ; a value of 1 will return the matching value itself , which is not of much use ; practically therefore , the third parameter can vary from 2 through 20.
In your example , the range is just one column ; specifying 2 as the third parameter will result in an error.
Secondly , the first parameter of the VLOOKUP is supposed to be a single value or cell reference , not an entire column reference. Of course , as long as you do not enter it as an array formula , Excel will not complain , but will take the value in column B in the same row as the cell where you put this formula in ; this may or may not be what you wish to do.
It is always preferable to specify one single value , and concrete range references e.g.
=VLOOKUP($B$13,'[Sales Report]Accounts'!$B4:$C1050,2,FALSE)
Case sensitive lookups
See these links for more information :
http://support.microsoft.com/kb/214264
http://www.atlaspm.com/toms-tutorials-for-excel/toms-tutorials-for-excel-case-sensitive-lookup/
