Index & match for multiple criteria between 2 dates data
Abhijeet
Hi
From 2 dates which dates are follow between the dates return the data i need so please tell me how to do this
I used advanced filter to pull the data but i need data set 2 in front the data so please tell me how to do this
Yes i also tried this before but i data is more & which not in data set 1 then this is not work means data set 2 in front not pull the same so please tell me how to pull in that case
I request you pls don't hang the english. You may use your native language to explain better!
Change I3 = ">"&DATEVALUE("1-1-2015")
Please tell me in this formula =COUNTIFS($A$3:$A$16,H3,$C$3:$C$16,">="&I3,$B$3:$B$16,"<="&J3)
How to use Index match formula to return value
