Index Match assign department based on employee and Job
Hello Guru
Can I get some help in solving my excel problem.
If the employee is working on J366 then the dept should be picked from codes tab. If the employee is working on Management 2021 or PTO 2021 then the dept should be picked from emp tab
Example: if Employee-5 works on J366 the dept is TIP. If Employee-5 works on Management 2021 or PTO 2021 then the dept should be PIE.
Thanks for all your help.
excelnovive2000, Good morning.
Try to use:
E4 -->
=IF(OR(D4="Management 2021";D4="PTO 2021");INDEX(emp[Depts];MATCH(B4;emp[Employee];0));INDEX(codes[Dept];MATCH(D4;codes[Analytic Account];0)))
Push it down as necessary.
Is this what you want?
I hope it helps.
Try to use:
E4 -->
I hope it helps.
Thanks Marcilio. That worked. Really appreciate your help
