Index and Match with multiple criteria
Manny Singh
Hello Masters,
Please see attached file for which I need some help putting Index and Match formula with multiple criteria.
When I select values from dropdown for Column 1 & 2, a formula looks up corresponding value in Column 3, 4 & 5.
I have put sample values in Column 3, 4 & 5 for example sake.
Tried Index and Match but multiple criteria are beyond my excel skills, would appreciate some help, please let me know if not clear.
Cheers, Manny.
Is there a problem in column A,Weld Type ,Getting listed first in each section?
So more efficiently, and can be avoided volatile functions(INDIRECT).
And what version of Excel you use ?
David
Try…..
In J15, formula copy across to L15 :
=IFERROR(INDEX(C5:C25,MATCH(SUBSTITUTE($H15,"_"," — "),$A5:$A24,0)-($H15<>"Pipe_Groove")+MATCH($I15,INDIRECT($H15),0)-3),"")
and, select J15:L15 >> Custom cell Format, in the Type box enter: ;;;@
Bosco
Hi Bosco,
I appreciate your help and like your skills.
Just few queries if you can respond please:
what's role of function ($H15<>"Pipe_Groove")?
what's role of indirect function MATCH($I15,INDIRECT($H15),0)-3)?
And custome cell formatting ;;;@?
I am learning slowly and if you could explain these functions, would be very helpful.
Hi Bosco,
The posted formula is a simplified from this one
=IFERROR(INDEX(C5:C25,MATCH(SUBSTITUTE($H15,"_"," — "),$A5:$A24,0)-($H15<>"Pipe_Groove")-2+MATCH($I15,INDIRECT($H15),0)-1),"")
into this one
Formula explanation :
1] This part : "...-($H15<>"Pipe_Groove")-2... " --> result will give -2 or -3. Row Position adjusting in respect of the 1st criteria (Weld Type) .
2] This part : "...MATCH($I15,INDIRECT($H15),0)-1... " --> Row Position adjusting in respect of the 2nd criteria (Position) .
3] Custom cell formatting ;;;@ --> to remove 0
Bosco
