I want to copy & paste data using VBA in single click
Ankur Kumar
Hi all,
I have a work having large number of data in different column say 50 column now i need to copy as paste from one sheet to another where column's data differe from one another, i need VBA coding so that i can move data from one sheet to other in same workbook by click single button.
If you need sample file so that i can provide in the continuation of this thread.
Thanks in advance
Ankur
Will you please attach a sample Excel workbook?
1. Make sure that your sample data are REPRESENTATIVE of your real data. The use of unrepresentative data is very frustrating and can lead to long delays in reaching a solution.
2. Make sure that your desired results are also shown (mock up the results manually).
3. Make sure that all confidential data is removed or replaced with dummy data first (e.g. names, addresses, E-mails, etc.).
4. Try to avoid using merged cells as they cause lots of problems.
Please pay particular attention to point 2 (above): without an idea of your intended outcomes, it is often very difficult to offer appropriate advice.
While you have shown us your raw data, there is not enough information for us to provide you with an answer. Please explain in detail using your sample data the criteria for moving the data. Which items are being compared? What basis? Although we have expertise in Excel here, we have no mind reading skills so you need to be explicit in your explanations.
