I need help to work with a Gantt Box Chart
Tom2012
I am having trouble in getting the vertical red line, “the flood” to print with the chart. See the attachment.
Is there a way to make a vertical red line in the chart without using a text box? And it would be part of the chart itself.
Can you help me with this?
Thanks,
  • Creation to Joseph 1-7-15.xlsx
I printed page 1 of your spreadsheet (in monochrome) and the red line appeared with no problem. Does it not appear on a color printer?
@Tom2012
What kind of problem?
It's red and it's transparency is 42%.
Would it 'work' better if You could select 'lighter red' without transparency?
@Tom2012
What kind of problem do You have?
Print it out to file and send it here.
If You can say only 'Not work', it's challenge to help.
Need to see the output.
