How to retrieve answer from a certain column using figure within a range
Hey guys,
Please help me create an excel formula to give me the result from a certain column if the data amount is within the range given. I could not make use of the index_match formula since given amount is not an exact match and the use of IF function is not possible due to number of formulas needed. I tried rounding off the figure so it would equal the Monthly Salary Credit for easy referencing but to no avail since it would needs rounding up and rounding down.
I have attached the file for reference and thank you in advance.
  • SSS Contributions.xls
Hello Guys, (Chihiro and Bosco_Yip)
Once again, thanks for the help. These helps me a lot and I continue to have new and additional learnings from you all.
