How to replicate data in column B with column A [code snippet required]
Mr.Karr
With the sample file attached, there are 2 columns. Column A has ID that is unique. Column B has comma separate values.
Wherever there are multiple values in columnB, ID in columnA has to be replicated to take values from columnB and create multiple rows accordingly.
IDNamesIDNames
123
Pencil, Paper, Blue Pen, Box
123Pencil
123Paper
123Blue Pen
123Box
Sample file attached. Thanks in advance.
According to your attachment a VBA beginner starter demonstration :​
Sub Demo1()
    Dim V, R&, L&, S$()
        [E1].CurrentRegion.Offset(1).Clear
        V = [A1].CurrentRegion.Value2
        R = 2
    For L = 2 To UBound(V)
            S = Split(V(L, 2), ", ")
        With Cells(R, 5).Resize(UBound(S) + 1)
            .Columns(1) = V(L, 1)
            .Columns(2) = Application.Transpose(S)
            R = R + UBound(S) + 1
Using Power Query/Get and Transform found on the Data Tab. Here is the Mcode to split the cells into rows.
let
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"Names", type text}}),
    #"Split Column by Delimiter" = Table.ExpandListColumn(Table.TransformColumns(#"Changed Type", {{"Names", Splitter.SplitTextByDelimiter(",", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "Names"),
    #"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"Names", type text}}),
    #"Trimmed Text" = Table.TransformColumns(#"Changed Type1",{{"Names", Text.Trim, type text}})
in
    #"Trimmed Text"
Data Range
[Table="class: grid"][tr][td] [/td][td]
A
[/td][td]
B
[/td][/tr]
[tr][td]
1
[/td][td]
ID​
[/td][td]
Names​
[/td][/tr]
[tr][td]
2
[/td][td]
123​
[/td][td]
Pencil​
[/td][/tr]
[tr][td]
3
[/td][td]
123​
[/td][td]
Paper​
[/td][/tr]
[tr][td]
4
[/td][td]
123​
[/td][td]
Blue Pen​
[/td][/tr]
[tr][td]
5
[/td][td]
123​
[/td][td]
Eraser​
[/td][/tr]
[tr][td]
6
[/td][td]
123​
[/td][td]
Keyboard​
[/td][/tr]
[tr][td]
7
[/td][td]
547​
[/td][td]
Apple Gala​
[/td][/tr]
[tr][td]
8
[/td][td]
547​
[/td][td]
Orange​
[/td][/tr]
[tr][td]
9
[/td][td]
547​
[/td][td]
Banana​
[/td][/tr]
[/table]
File attached for your review.
