ThrottleWorks
I am using below mentioned code to create e-mail.
This code creates e-mail perfectly. However, e-mail body does not starts from line 1.
We can see an empty line visually before e-mail body starts.
For example, e-mail created by macro will reflect as below
--empty line –
Have a nice day ahead.
Manually created e-mail will reflect as below.
Can anyone please help me in this.
--empty line –
Sub MailMacro()
Dim EmailRng As Range
Dim OutApp As Object
Dim OutMail As Object
MyPath = ThisWorkbook.Worksheets("Mapping").Range("D2").Value
With OutMail
.To = EmailSht.Range("B1").Value
.CC = EmailSht.Range("B2").Value
'.BCC = EmailMapSht.Range("B1").Value
.Subject = EmailSht.Range("B3").Value
.Attachments.Add MyPath
.HTMLBody = RangetoHTML(EmailRng)
.Display
Set OutMail = Nothing
Set OutApp = Nothing
Function RangetoHTML(rng As Range)
Dim fso As Object
Dim ts As Object
Dim TempFile As String
Dim TempWB As Workbook
Dim MacroBook As Workbook
Dim EmailSht As Worksheet
Set MacroBook = ThisWorkbook
Set EmailSht = MacroBook.Worksheets(Sheet3.Name)
TempFile = Environ$("temp") & "\" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
rng.Copy
Set TempWB = Workbooks.Add(1)
TempWB.Worksheets("Sheet1").Range("A1").PasteSpecial xlPasteAll
With TempWB.Sheets(1)
.DrawingObjects.Visible = True
.DrawingObjects.Delete
On Error GoTo 0
With TempWB.PublishObjects.Add( _
SourceType:=xlSourceRange, _
Filename:=TempFile, _
Sheet:=TempWB.Sheets(1).Name, _
Source:=TempWB.Sheets(1).UsedRange.Address, _
HtmlType:=xlHtmlStatic)
.Publish (True)
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
RangetoHTML = ts.readall
ts.Close
RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", "align=left x:publishsource=")
TempWB.Close savechanges:=False
Kill TempFile
Set ts = Nothing
Set fso = Nothing
Set TempWB = Nothing
End Function
