Hi everyone!
I have a "source database" of about 1500 rows and 7 columns.
In my userform, I fill 3 listboxes with unique values from 3 of my source database columns. These listboxes will act as dynamic filters:
The user can select items in the listboxes, which will 'filter' my table and display, in a fourth listbox (called Preview), only the table rows which correspond to the selected items.
I don't think my code is very good at the moment. It works, but when the selected items are such that about 500 items have to be displayed in my Preview listbox, the program takes a few seconds to respond.
First listbox allows for multiple selections. Here is how I get its data:
Other listboxes are for room and department (dep):
Now for the code that takes a long time to process: I loop in my database table (for x = 0 to ...). I start with my category (the Variant variable) and loop through all its values (for y = 1 to narray). For each value, I check if the cell in my table corresponds. If it does, check my second listbox "filter". Same for my third filter.
For x = 0 To Me.LbCat.ListCount - 1
If Me.LbCat.Selected(x) = True Then
narray = narray + 1
ReDim Preserve cat(1 To narray)
cat(narray) = Me.LbCat.List(x) 'cat is a Variant
Next x
For x = 0 To Me.LbDep.ListCount - 1
If Me.LbDep.Selected(x) = True Then
dep = Me.LbDep.List(x)
Next x
For x = 0 To tablerange.Columns(2).Cells.Count
If narray = 0 Then GoTo DemNext
For y = 1 To narray
If tablerange.Cells(x, 2) = cat(y) Then
DemNext:
If Room = "" Then GoTo DemNext2
If tablerange.Cells(x, 4) = Room Then
DemNext2:
If dep = "" Then GoTo DemNext3
If tablerange.Cells(x, 3) = dep Then
DemNext3:
UserForm1.LbPreview.AddItem
UserForm1.LbPreview.List(UserForm1.LbPreview.ListCount - 1, 0) = tablerange.Cells(x, 3).Value 'dep
UserForm1.LbPreview.List(UserForm1.LbPreview.ListCount - 1, 1) = tablerange.Cells(x, 4).Value 'Room
UserForm1.LbPreview.List(UserForm1.LbPreview.ListCount - 1, 2) = tablerange.Cells(x, 5).Value 'class
UserForm1.LbPreview.List(UserForm1.LbPreview.ListCount - 1, 3) = tablerange.Cells(x, 2).Value 'cat
UserForm1.LbPreview.List(UserForm1.LbPreview.ListCount - 1, 4) = tablerange.Cells(x, 7).Value 'place
UserForm1.LbPreview.List(UserForm1.LbPreview.ListCount - 1, 6) = tablerange.Cells(x, 8).Value 'limit 1
UserForm1.LbPreview.List(UserForm1.LbPreview.ListCount - 1, 7) = tablerange.Cells(x, 9).Value 'limit 2
ElseIf tablerange.Cells(x, 3) = dep And tablerange.Cells(x, 4) = "N/A" Then 'This line is here to display lines which have no room (N/A) but should still be displayed when the corresponding department is selected
GoTo DemNext3
Next y
Next x
