How to hide / unhide column by using formula
atulrajratna
How can we hide or unhide column by using formula when we are entering value in any cell.
e.g in A1 if i will enter 1 then Column F will hide and if i will enter any other number or if i will delete that 1 from A1, then Column F will unhide.
please help me in this.
Thank you!
Can't do it just using formulas. But you can use this event macro (right click on sheet tab, paste in)
[pre]
If Intersect(Target, Range("A1")) Is Nothing Then Exit Sub
If Range("A1") = 1 Then
Range("F:F").EntireColumn.Hidden = True
Range("F:F").EntireColumn.Hidden = False
[/pre]
