shahin
I've created a macro using XMLHTTP request to parse some specific fields from a table out of a webpage. The data I'm interested in are within the first two columns and they are : 1. Name 2. Link to the name 3. Company and 4. Link to the company. The first script I'm gonna paste can fetch the required data in the right way. However, my intention is to do the same using error handler. As I've zero experience to manipulate data using error handler, I wish to learn the same in the effective way.
The problem I'm facing with that table is that it has got first two "tr" without any "tds'". So when I run my script as it is, it encounters value error which is "run time error 91" in this case. How can I tackle this using error handler?
First try (successful):
The way I would like to move on (It is also working but I'm quite unsure whether I did it in the right way).
I pasted the first script to let you know that I'm not interested to go in that way as it may be a possible solution I may get.
Sub FetchTabularData()
Dim HTML As New HTMLDocument
Dim elem As Object, post As Object, R&
With New XMLHTTP60
.Open "GET", "https://admintool.noah-connect.com/widget/attendees", False
.send
HTML.body.innerHTML = .responseText
For Each elem In HTML.getElementsByTagName("table")(0).getElementsByTagName("tr")
Set post = elem.getElementsByTagName("td")
If Not post(0) Is Nothing Then
R = R + 1: Cells(R, 1) = post(0).getElementsByTagName("a")(0).innerText
Cells(R, 2) = post(0).getElementsByTagName("a")(0).getAttribute("href")
Next elem
With New XMLHTTP60
.send
On Error GoTo handler
On Error GoTo 0
handler:
Resume Next
Next elem
