HOW TO FIND THE DIFFERENCE BETWEEN VALUES IN SAME CELL?
bharath
HI,
I ATTACHED THE FILE
CELL A1= -1,-,1,-1 RESULT IN CELL B1 =" OK "
CELL A2= -1,-2,-1 RESULT IN CELL B2 = "NOT OK"
PFA
THANK YOU
  • DIFF IN SAME CELL.xlsx
You can use the Text to Column option to split your data in separate columns using comma as Delimiter, or the similar with following formula, to be entered in G2, copy across and down:
=TRIM(MID(SUBSTITUTE($E2,",",REPT(" ",LEN($E2))),(LEN($E2)*(COLUMN(A1)-1))+1,LEN($E2)))
Then you can easily differentiate between these results with simple COUNTIF or AND function.
hi,
as you said, i copied the formula in g2
but not getting required result
i attached file (with using formula)
Better to using formula instead of text to columns option.
may characters length increase..
In G2, copied down :
=IF(ISERR(-SUBSTITUTE(SUBSTITUTE(E2,LEFT(E2,FIND(",",E2&",")-1),""),",","")),"OK","NOT OK")
Bosco
