How to fill random numbers in a range of cells using auto-sum.
Hello friends and here's something i just discovered and would like to share
I was using the = RANDBETWEEN() to fill random numbers in a range of cells (B2:K200) and instead of using the 'usual' Ctril+Enter in B2 and then pressing the usual Ctrl+Enter, i used the 'auto-sum' button instead and got the desired results.
So u don't really have to use 2 keys......Ctrl+Enter.
The single Autosum works just fine.
Thought i'd share this.
Cheers!
Hi James,
I've just tried your method and it works if your cursor is in the formula bar, but if you put the RANDBETWEEN() in B2 first, then select your range B2:K200 and then hit the auto-sum you get a random number in each corner of the range that are identical. Just thought I'd share that.........can't think where it can come in useful though o_O:DD:DD
