usually for workbook that consist of more than 10 (or 50....), we will open up a blank workbook, Data > New Query > From Other Sources > blank query, then input the M Code
= Excel.Workbook(File.Contents("C:\Users\JO_HOME\Documents\Seowkian\Technology & IT\chandoo\log.xlsx"),null,true)
you must change your path that save log.xlsx
then continue transforming till all the 100 worksheets structurally appended in one single table, then make use of this consolidated table to reference for any outcome that you want, reach certain range then action etc
However, your original worksheets are too dirty, a lot of invalid data type, I got difficulty transforming for you as I don't understand all your data fields
Probably other forum guy can advise you VBA
