How to display true 0 when source is 0 and blank is blank?
melzjm
Hi again,
Thank you everybody for being kind. It helps me go through my relationship with excel a bit better everyday.
I have this formula (='Test.xlsx'!$E$14) to return the value of another sheet's cell.
My problem is whenever the source cell is blank , it'll return 0 and if the value of the source cell is a true 0, it'll return 0 too.
I have tried to conditional formatting, I ended up, making all 0s blanks including the true 0s.
I used =if('Test.xlsx'!$E$14=0,"0.00%",'Test.xlsx'!$E$14) to force all 0s to display ).0% but it displays 0.0% with blanks too.
Any input is appreciated.
Thanks,
Melzjm
Hi melzjm,
You have set your excel to display "blank" as "0", thats why its showing all "blanks" as "0"..
What.. you have not set you Excel.. !! then why ..
Excel > Option > Advance > Display Option for this Worksheet > "Show Zero in Cells that have ZERO value" is checked in your PC.. ;)
BTW..
What exactly do you want..
* Display 0 as 0%, Blank as Blank and Number as Number% then use the below..
=IF(LEN('Test.xlsx'!$E$14)>0,('Test.xlsx'!$E$14 & "%") * 1,"")
or please supply some demo data of your output.. :)
Deb
Hi, melzjm!
I think that it should be like this:
=IF('Test.xlsx'!$E$14)="","",'Test.xlsx'!$E$14)
Display blank even if it has a formula which should display blank, and display anything including zero if properly formatted when other values.
Regards!
