ThrottleWorks
I am new to SQL, I am trying to derive data based on the dates.
There are 3 conditions.
1) Date should be between 29/10/2015 and 27/10/2015, both 29 and 27 are considered
2) Name should be Yamaha
3) Region should be East
I am able to manage condition 2 and 3 however I am not able to do condition 1.
I tried copying various solutions online but I was not able understand it.
Sorry for asking readymade answers, please help if possible.
Will try to upload sample file in some time.
I am using below mentioned code.
Sub sbADOExample_4()
'Column A Serial No
'Column B Date
'Column C Name
'Column D Region
'Column E Count
'No of rows in table, 11
'No of columns in table 5
Dim Macrobook As Workbook
Set Macrobook = ThisWorkbook
Dim MasterSht As Worksheet
Set MasterSht = Worksheets("Master")
Dim TempRng As String
TempRng = Replace(MasterSht.Range(Cells(1, 1), Cells(11, 5)).Address, "$", vbNullString)
Dim MyQuery_1 As String
Dim ReturnArray
Dim NewConnection As New ADODB.Connection
Dim New_RecordSet As New ADODB.Recordset
Dim DBPath As String
Dim sconnect As String
DBPath = ThisWorkbook.FullName
sconnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & DBPath & _
";Extended Properties=""Excel 8.0;HDR=Yes;IMEX=1"";"
NewConnection.Open sconnect
sSQLSting = "SELECT * FROM [" & MasterSht.Name & "$" & TempRng & "] WHERE Name = 'Yamaha' AND Region='East';"
New_RecordSet.Open sSQLSting, NewConnection
Sheet2.Range("A2").CopyFromRecordset New_RecordSet
New_RecordSet.Close
NewConnection.Close
