How to delete visible cells from range without deleting headers
ThrottleWorks
I am trying to delete visible cells from a filtered range.
As of now I am able to do it however I am not sure where it is the correct way.
Is there a single line code, which will help me to delete visible cells from the range but will not delete headers.
At present I am using "Range(TempSht1.Cells(2, 1), TempSht1.Cells(TempLr, TempCol)).SpecialCells(xlCellTypeVisible).EntireRow.Delete" this line to avoid deleting header.
Can anyone please help me in this.
Set TempRng = TempSht1.Range(TempSht1.Cells(1, 1), TempSht1.Cells(TempLr, TempCol))
        Selection.AutoFilter
            TempRng.AutoFilter Field:=Col, Criteria1:="=Honda", Operator:=xlAnd
            TempLr1 = TempSht1.Cells(Rows.Count, Col).End(xlUp).Row
            If TempLr1 > 1 Then
    On Error GoTo 0
If TempLr1 > 1 Then
On Error GoTo 0
Hi !
No need to select neither SpecialCells
as Copy like Delete methods use only visible cells !
From source range with headers row, just need an Offset.
With a dummy sample workbook, I could post a demonstration …
