How to Delete first Duplicate values?
sreekhosh
Here "Raj" and "Sree" are duplicate value. I need to remove the No.1,2,3 and should keep No.5 and 6, that means the last updated values.
Please provide a macro for this
No| Name| marks
1| Raj| 0
2| sree| 0
3| Raj| 0
4| lena| 0
5| Raj| 15
6| Sree| 12
Sreekhosh.AP
Easiest way is probably using formulas. we could automate if needed.
1. Formula in helper column:
=COUNTIF(A2:A$10000,A2)>2
2. Filter this column for all "TRUE" values.
3. Delete all of these rows.
4. Unfilter
5. Remove helper column, if desired.
If you really want a macro, here's one to work on col A
[pre]
Sub KeepLastDupe()
Dim x() As String
Dim z As Variant
Dim LastRow As Long
Dim newValue As String
With ActiveSheet
LastRow = Cells(.Rows.Count, "A").End(xlUp).Row
ReDim x(0 To LastRow)
For i = LastRow To 2 Step -1
newValue = Cells(i, "A").Value
'Create a filtered array
z = Filter(x, newValue)
If UBound(z) >= 0 Then 'dupe found
'If dupe, delete the row
Cells(i, "A").EntireRow.Delete
'otherwise, add value to our array for future reference
x(i) = newValue
[/pre]
Here's one more approach.
[pre]
Public Sub KeepLast()
Dim i As Long
.comparemode = vbTextCompare
For i = Range("A" & Rows.Count).End(xlUp).Row To 2 Step -1
If .exists(Range("B" & i).Value) Then
Range("A" & i).EntireRow.Delete
.Add Range("B" & i).Value, Range("B" & i).Value
[/pre]
