How to create Folder using VBA macro
You can use the code posted in loop or repeat the line 10 times to get desired result.
Could you explain your requirement clearly?
i have a list of names in the excel sheets. i want to create the folder for the same and named in the excel sheets
for example in the the excel sheet range i have following names
Jan, Feb up to Dec. so the total name is 12 i want to create the 12 folders and folder name is jan, feb up to dec.
